cam belt water pump change
iam looking to change cam belt and water pump  on my 15 plate  2.0 durotorq (engine code t7db ) focus , i have looked at genuine ford parts and gates belt  theres a fair bit of diffrence in the price what do people recomend  ford or gates ? ,i will be keeping the car for a long time as i have had it since new , also any pifulls to be aware of doing the job i have done a couple of 1.6 diesel focus are they similar?  does any one know were i can get a good workshop manual  for the 2.0 durotorq
Please amend the year on your profile which says it is a 2019 Focus. This will cause much confusion in the future since a 2019 Focus is a Mk4 with a 2.0 EcoBlue engine and a wet belt.
2015.JPGall done thanks
Our belt was replaced at 10 years with a Gates kit (I believe a Tier 1 supplier). The garage said that they would only warrant the change if they used that supplier which is their preferred one. Now 14 years old and no issues:
https://www.gates.com/us/en/markets/automotive-and-on-highway/passenger-cars-and-light-commercial-vehicles.html
Try Haynes as perhaps (unless anyone knows otherwise the best/only way for DIY - others are for garages and are VERY expensive?):
https://haynes.com/en-gb/car-manuals
There is the standard manual or Autofix or bundles - you'll need to choose (they complement each other so I have both):
https://haynes.com/en-gb/which-manual-should-you-choose
Hi thanks for the reply gates looks good then
