Horn working intermittently
Hello
have a 2013 fiesta1.25 duratec
horn on steering wheel works intermittently
checked fuse under bonnet looks fine
thats the limit of my knowledge
any ideas on what could be the problem
thank you
Wiring to the horn is most likely rotten. Take the O/S headlight out to access it.
I assume that you don't have a multimeter.
Recommend that you get an auto electrician to take a look before you cause the airbag to explode.
  • 4 weeks later...
99% it will be a faulty horn..cheap to buy on fleabay
Check connectors when fitting the spray wd or apply some grease to deter water
