Focus MK4 1.0 125ps chain like rattling noise
Hello,
So, just a quick one.
Ive got this rattling like noise when the engine down revs, ive read in previous posts its
- the air recirculation vent
- The mechanical fuel pump
- Perfectly normal for the engine.
Is this the case at all?
I should note the noise is loud when the engine is cold.
Attached is a link to the video showing this.
https://drive.google.com/file/d/1tZJAONABtFjsp3smtX961fmLSCnlovJj/view?usp=drivesdk
It's Turbo wastegate rattle mate. They all do it at some point and very common. Not really an issue to be too worried about as the turbo is still operating correctly just when the wastegate actuator gets too loose it can cause boost issues. No quick fix known (currently working on one), other than replacing the turbo but could quite possibly happen again after 10k miles.
Ah, that would explain that then! How much does it typically cost to replace a turbo and is it a simple replacement?
It depends on the year of your car as the newer 1.0's with the wet chain have the turbo located at the back of the engine and are abit more difficult to work with but for rough prices I would say, £300+vat for a reconditioned turbo and roughly 4 hours labour £200ish+vat.
This it is 🙂
