Focus mk2.5 Rear Wheel Bearing Hub Replacement
After several disasters today I may need to replace a rear wheel bearing hub - job to remove the hub so I could replace the splash shield along with new calipers discs and pads etc failed miserably with RHS external torx bolt heads all crumbled away and totally unremovable by normal means.
So if hub has to come off it’ll likely need grinding off from the outside.
Anyone got experience with different suppliers for a new hub? Mines the ABS version with the sensor on the back
