Luggage compartment won't unlock
S-Max 2010
Rear door/luggage compartment lid won't open either by remote control or manually.   I have tried resetting the ECU by disconnecting the battery, and that sorted some other minor glitches but not the main problem.
Hope it's not the boot switch that is causing your issue, no end of these get corroded inside then the micro switch acts up, many cases unable to open or the boot keeps popping open, happens on other fords with the similar switch.
https://www.spareshut.com/products/ford-s-max-2006-2014-tailgate-boot-lid-release-switch-button
