Drips from the overhead lighting!
Hi. First post. 2017 Titanium 2.0d 180 101k. Just had the head gasket done and running so much better.
When the rain is incredibly heavy I succumb to a drip from the lighting control panel behind the windscreen. Has anyone else had this?
Autoglass have suggested it's a manufacturer error and won't touch it unless I go for a remove and replace costing a large chunk of money and then they won't guarantee the glass.
glass roof/sunroof? see if you can find the drainage channels on either side  of the roof and give em a clear out
Possibly a disconnected drain tube too.
You will need to drop the headliner and see
Thanks both. It's not a glass roof or sunroof. Headlining will be coming down at some point.
It can only be that the windscreen seal is faulty then.
If it is, it'll have to come out, sorry
Currently negotiating with my insurers. This is going to be fun!
Should've just cracked it if you know it's leaking and covered
