Refill automatic transmission fluid
I needed to refill the automatic transmission fluid of my 2020 gord focus mk4 because i did replace the drive shaft. I tried to find out the type of fluid and hot to refill. But I can't find anywhere. Can you please help me. Thanks
As there has been no immediate reply I would have thought the handbook would give that information OR ask the Ford dealer OR check with your local motor factor OR I would be amazed if there wasn't an answer online (but you'll need to know the transmission type which I don't, OR hopefully someone else on here will see this?
There's normally a label on the transmission somewhere, telling you the spec.
But I'm 95% sure a MK4 8 speed torque converter auto is ULV, unless they reverted back to LV for MK4, which I highly doubt
If you are a 7 speed DCT then that information will be incorrect and you need to go to a dealer parts dept who will tell you
