Exhaust Camshaft Position Response Slow Fault
Hi There,
I have been having an EML coming on and also a reduced jolty performance over the past little while, I have serviced the car (flush also added prior to drain), replaced both VVT valves, camshaft sensors and still have the reduced performance from time to time and a fault: P000B-E1 Exhaust B Camshaft Position Response Slow when the EML appears. It does run okay but then has its days when it feels very jolty and slow in the uptake but once at speed she drives fine.
Its been getting the most of me and I cant get to the bottom of it. Its the 1.6i VVTi engine, hopefully someone could shine some light.
Thank you,
Joshua
What's the IC code? Instrument Cluster
Hi Dave, its just a can communication generic fault. Just not understanding the lack of power and the EML for exhaust camshaft slow
That's why I asked.
Is there a chance that the common cluster solder fault issue is causing this problem?
Have you had the cluster tested?
4 hours ago, DaveT70 said:
That's why I asked.
Ive had it previously repaired by Olly Jones, the legend of clusters. Good shout though as I know these can throw wobblers or messages on the speedo
OK check your wiring is good then, you could have a breaking down wire somewhere
