Ford focus 2011 1.6
Hi all. New on here. Having trouble with engine management light on. Diagnostic says its Bank 1 sensor (front lamda O2 sensor which has been changed) still hasn't fixed problem. Cleared faults. Come back again. Engine running too much air. Sounds rough. Any ideas how to resolve?
Paul
What is the exact lambda sensor fault code?  Some point towards the sensor, some towards wiring, others point towards a mechanical issue.
On this engine I would be expecting a vacuum leak.  Most likely split PCV hose under the inlet manifold.
The AA man did a leak test and couldn't find any leaks. That's what's so confusing. I'm not mechanic so not sure where to start. Don't think it's the MAS sensor. Still reading lean Bank 1 but changed sensor. If I take it to garage it will cost a fortune for them trial & error to find problem i guess?
