Seat lever
Just curious. Does anyone here have a problem where the seat adjustment lever literally droops down (the one that moves the seat forward and backward)? Normally the lever should be a little higher and not touching the carpet. I took a closer look and the yellowish plastic fastener that holds the machanism together seems the have broken (most likely due to age). I have searched high and low and nobody sells that part. Not even Ford.
You may need to get a seat from a scrappy and take the parts for yours
I think i will just custom make that bit that broke.  Thanks.
