Start/stop light not going out
My start/stop system has stopped working and the light is not going off. I’ve just fitted a new battery , is there a way to reset this?
Did you reset the BMS after fitting the new battery?
If not, fully recharge the new battery, then reset the BMS.  If the stop/start still doesn't work after that, there is a separate fault causing it to be permanently disabled.
I wish my stop/start would stop working.
