Mk1 steering and front suspension
Does any one have a diagram of the steering system and front suspension system of a mk1 focus
Exploded diagrams can be found here - Ford | Parts Catalogs | PartSouq
I take it your looking at replacing the steering rack ? There's 1 bolt on each side that hold the sub frame up next to the shockers don't undo them 1st undo the ( 4 ) if l remember right at the sub it's self 1st then slowly undo the other 2 to the point just before they are fully removed this will allow you to swing the sub forward by so much. You need to remove the anti roll bar to get to the rack ( be careful the pipes to the rack normally rust in very bad so don't instantly try removing soak with kitchen cleaner white vinegar ) it'll also allow you access to the bolt that hold the steering rack to the column but you also need to undo the 1 inside the foot well too.. been there done it 😂👍
