Mk6 Studio Key Start Issue
I've got a 1.2 fiesta studio (2017) a few months ago and its been fine until today. drove a short distance to petrol station and when i went back to it i saw a "key not detected" message and the car wouldnt start. all the lights etc come on then off but it doesnt crank. i went back to it an hour or so later and it worked fine. i drove it home and tried again; turn off, turn on, started, turn off, turn on, started then third time not joy - no crank no thing - all the lights. The odd thing is that even when it does start, it's still saying no key detected. I only have one key unfortunately. I've put the battery on charge overnight in case its that but i wanted to see if anyone out there had seen this?
Your Mk7 Fiesta keyfob battery is dying.
Put a new expensive good quality CR2032 battery in the fob and all will be well.
ok, i did think that but its battery-less. there's no buttons.  I think its only got a transponder in i, a bit like thist image.thumb.png.aff32cf4a75fbb0004259bfab9cc9325.png
I think you need to clarify exactly what car this is. In your profile it's a 2014, in your query it's a 2017?
Either way, a Mk 7 facelift (aka Mk 7.5) and presumably it's a 1.25.
That key looks a bit odd - is it an original Ford key?
The Studio is a bit of an outlier as it was mainly for fleet customers and I haven't seen a spec** for it, but Iirc all other Fiesta versions at that time had a remote key. (Possibly in some cases the car was supplied with one remote key and the spare key is a "manual one").
** According to Parkers guide (not the most reliable souce, unfortunately) it would have had remote locking when new.
sorry, my bad yes it's a 2014. the key is Ford stamped but its the only one we have so it is possible there was another remote one. trying the car again today, with a full battery and its more intermitent. think i'll pay a visit to ford tomorrow and get a bit more background on the car if i can.
If you send me your VIN number by PM, then I'll get the build sheet for your car.
Registration: xxxxxxxx
VIN: xxxxxxxxxxxxxxxxxxxxxx
Build Date : 26.08.2014
Vehicle Line : FIESTA 2012-2019
Engine : 1.25L DURATEC 16V EFI(60PS) - SIGMA
Transmission : 5 SPEED MANUAL TRANSAXLE - B5/IB5
Emission : STAGE V EMISSIONS
Air Conditioning : LESS AIR CONDITIONING
Body Style : 3 DOOR SALOON
Drive : RHD FWD
Axle Ratio : 4.06
Version : SERIES 10
Exterior Paint : FROZEN WHITE
Interior Fabric : MAX /CHARCOAL BLACK
Territory : (+)"GB"
start warranty: 22.10.2014
Owner’s Manual (Vehicles Built From: 3/21/2014 Vehicles Built Up To: 1/11/2015) (HTML)
14" progressive whl cvr-sty e
175/65r14-t lw roll resistance
4 speakers frt/2 speakers rr
4.06 final drive ratio
5.5 x 14" semi styled stl whls
95 0ctane level gasoline
a/v jack
accessory media hub 1xusb
air bag restraint-driver
air bag restraint-pass
air curtain restraint-lh
any brand tire vendor
basic icp
blt/d&p frt/1&2 row/d kne bag
body colored painted roof
brake calipers-non painted
brakes-hla/esp/tc/abs
bumper energy reinforements
centre console - base
comp unique for steel whls
complx reflect headlamp design
conventional headlamp control
courtesy light delay feature
day/night inside mirror
daytime running lamps
door trim pnl insert-cloth
driver seat air bag restraint
dual note electric horn
dual pwr/htd/app/mem/signal
electric power steering 1
electronic emerg brake assist
eng immobilizer theft sy-integ
ext door handle-self coloured
ext mirror finish-black
filter cowl air intake
first aid retain strap
fixed front seat belt mount
fixed rear side window
foot pedal design - standard
frnt bump-body colr/lwr accent
front 2-way headrestraints
front headlamp leveling
front stablizer bar
frozen white
frt st blt bckl pre-tns drv/ps
fu/tnk fill nk-with inhibit
gear 3.58/1.93/1.28/0.95/0.76
glovebox illumination
great britain
header courtesy light
high mounted stop lamp
hill launch assist
ice feature pack 7
inflatable knee bolster driver
int envirn color-chrcoal black
int feat color-charcoal black
isofix hard point attachment
kit-enhanced tire repair svc
l/frt splash guards/mud flaps
lift/decklid hndl ext-body clr
load compartment light
load floor carpet
low level audio with usb
low series analog cluster
ls drv st back mtd map pocket
ls pass st back mtd map pocket
manual 2-way drv seat adjuster
manual 2-way pass seat adjust
marketing level 1
molded headliner-complete
mph/kph speedometer
niehl, cologne plant build
no description available
non locking lug nuts
normal temp zones
package tray-rear removable
parking brake - mechanical
pass air bag deactivation
pass seat air bag restr
plastic handbrake grip
power door locks
power frt disc/rear drum
power point plug
pwr frt w\'dows one touch up/dn
rear bump-body colr/lwr accent
rear headrestraint-2 way
rear overhead courtesy lamp
rear seat cushion-fixed
rear seat fold down-split
rear spoiler
recirculation heater
rr seat belts-3 point/inerta
seat back material-carpeted
seat-individual-l/b drv/pass
second row folding seat
snvsr-drv/mir/flap/tick pocket
snvsr-pass/mir/flap/tic pocket
soft feel gear shift boot
soft feel gear shift knob
st belt mndr-dr&pas/eu tel&snd
standard duty battery
standard duty suspension
standard green glass wndscrn
standard tire tread-front
standard tire tread-rear
starter equipment (-25c)
std electric starter
strg column-tilt/telescoping
strg wheel radio controls
strg whl-hard polyurethane
tailgate-powered upper
taillamps - led rear
tether anchorage restr-style 1
tinted glass-complete
tire inflation monitor lvl ii
tire pressure sensors-433 mhz
trans linked rr washer/wiper
two line mfd
unleaded fuel capability
var itrmt wipe+anti-drip wipe
warning device retaining strap
less a/c refrigerant
less anti-theft system
less auxiliary heater
less blue tooth interface conn
less brake system-regenerative
less bulk head
less camera
less cargo area cover
less cigar lighter
less city safety
less cooling pack
less cornering lamps
less dr entry remote cntr unit
less dress up rso
less elect windshield defrost
less emergency assistance
less exhaust pipe extension
less exterior door frame mldgs
less exterior dress up package
less exterior rocker panel mld
less floorwell lights
less front bumper extension
less front floor mats
less front fog lamps
less front parking aid
less frt door sill protection
less headrestraint-rear center
less heated steering wheels
less heated washer jets
less hub covers
less interior light group
less interior pack
less keyless entry system
less lighting packages
less load rest
less lumbar seat sup-driv seat
less media gateway module
less mkt flex prep pack
less mph engine governor
less navigation center
less navigation data
less outside temp thermometer
less paint package
less puddle lamps
less pwrpnt plug-load cmprtmnt
less rear floor mats
less rear intr assist hndl
less rear seat ash tray
less rear splash guards
less reverse gear alarm
less reverse parking aid
less roof line conversion
less rr window protector
less sales badge
less smokers package
less spare wheel
less spd audible warn device
less special equipment package
less special order paint
less speed control
less svo application/label
less svp
less temp control driver seat
less temp control passngr seat
less temp controlled glove box
less tie down hooks
less trailer coupling
less tripminder
less u/body corrosion protect
less voice activated modules
less window/rf pnl auto close
It would appear to me that the car was built without remote control.
