Fan
Have a Ford Fiesta 2010 and when the fan is turned up high it makes a whirling noise, when it is turned down to half way the noise stops, anyone know what this could be or causing it? Thanks
Not guaranteed but could be the pivot bits it turns on need greasing.
thanks, is this something i can check myself and grease?
If your able to view it then the answer is yes to both questions. If not you'd need to remove parts of the dash maybe to access it. My van does it when it gets warm but I'm lucky enough to be able to do what's needed. Hopefully it is possible for you to diy it n it solves the problem 👍
You might wanna watch this first n decide for yourself about it, as removal seems the only way to get the grease into the pivot 🤦‍♂️
