Pcm Kaput!
Please help guys :)
Vehicle Details-
Make & Model: Fiesta
Year: 2007; Miles clocked: "15002"
Engine: 1.4 L , Duratorq-TDCi
Background:
As I started driving I noticed the "Battery Warning Light" illuminates permanently.Immediately, switched-off the AC, Fan and rushed to the nearest Ford workshop.
There was no Engine Light "On" (MIL), neither while driving nor, while admitting the Car into the garage.
Findings reported by the garage:
"As per the diagnosis done on the scanner, we found that the alternator is not charging the battery; radiator fan is working at high RPM and AC compressor clutch does not engage at times due to the PCM has a internal short which in turn has also damaged the alternator."
Advice sought:
1)When there is no Engine Warning Light On (MIL), then how can it be
PCM failure?
2)In any circuit there is a fuse to take-care of shorting, wouldn't a
shorting lead to fuse blow-off and thus protect PCM?
3)Does the diagnosis appear correct?
thanks
Raulph
Please help guys :)
Vehicle Details-
Background:
Advice sought:
PCM failure?
thanks
Raulph
the pcm runs everything so if therews a short in it it wont illuminate the mil as it thinks its correct if you know what i mean hope fords replacing these parts for you because at tyhat year and mileage i wouldnt be paying for it
Thanks....but shouldnt the engine light illuminate for any malfunction of pcm which includes "internal short"
