MAP sensor at 50-60 Kpa (sound of air leak in the hood)
**Ford Fiesta 5 2005 1250cc 75hp Duratec 16V engine**
Well, here is the explanation of the problem.
My car has been idling irregularly (the problem occurs when I accelerate in neutral above 2,000 RPM and sometimes it tends to stall, and sometimes it actually does stall, it also happens when the car is in gear and I hold the clutch pedal).
In the red square in the image is where the loudest sound comes from, as if it were an air leak or intake.
The MAP sensor reads 50 to 60 Kpa, whereas the normal is around 35~
Also, once when I went to perform maintenance on the spark plugs and ignition cables, I noticed there was a lot of oil in the spark plug well. (Possibly the valve cover gasket is faulty, causing a false air intake?)
