Engine warning ⚠️ (P2125)?
Hi guys, hope your all ok?
2013 fiesta - 1.25
I am randomly getting an error, and the code is;
P2125-86-28 - Throttle/pedal postion sensor/switch E - Circuit error.
Engine malfunction - spanner light with beeping etc
I did pop in to live data to get a reading from the throttle pedal, and both values work from 0 - 100% when pressing etc.
Trouble is its intermittent, some times it will happen and next ign cycle no warning etc so unsure if its the pedal?
Not had a chance to look into yet but anyone come across this?
Any help would be fantastic please 🙏
Unplug the connector and check for any corrosion on the pins. Not much else to check . My daughter had a fiesta 2013 and suspected throttle pedal fault. That was intermittent . I took connector off, checked the pins ok, refitted , switched ignition  on did full range of movement multiple times in quick succession. Ign off.
Said if the light came back on to come back and would fit a second  hand throttle pedal I bought off eBay and see how it goes. Never played up from that day onwards for next 3-4 years when it got written off by someone who hit it while parked up.
