P006A - MAP Volume Air Flow Correlation
Hello guys, I own a 2014 Fiesta 1.0 EcoBoost. Quick question: what is your MAF and MAP reading at idle? Context: I am running into the P006A Fault code and I am suspecting a vaccum leak. I tested the MAF and the 2 MAP sensors and they are fine. My MAF reading at idle is around 1.7 g/s (0.226  lbs/min) with the engine hot. Just need some live readings to compare mine with.
The entire error code is P006A:62-6C, if you also have any ideas what the last 4 digits mean.
Thank you!
Edited by Adi23
Remembered something
