No injector correction values in FORScan
Hi everyone,
I have a 07/2011 Ford Fiesta 1.4 TDCi (EDC17C10 ECU) and I’m trying to read the injector correction values (fuel injector balance / cylinder correction values) using FORScan.
I’m currently using a generic Bluetooth ELM327 adapter (cheap Amazon model). The PCM module is detected and I can read standard OBD-II data (RPM, rail pressure, temperatures, etc.), but I cannot find any injector correction PIDs in the live data list.
I checked:
  • PCM live data (not generic OBD-II mode)
  • Full PID list (expanded view)
Still no injector correction values for individual cylinders.
My questions are:
Are injector correction values available on the 1.4 TDCi EDC17C10 via FORScan?
Do I need a better adapter (OBDLink EX, vLinker FS, etc.) to access extended Ford PIDs?
Are these values only accessible via IDS or dealer-level tools on this ECU?
Any help or confirmation from someone with the same engine would be greatly appreciated.
Thanks!
  • 1 month later...
If you mean individual injector compensation values, they aren't on the 1.6 so id say no.
If you mean the injector codes, they should be.
