Clutch switch
Put a clutch switch in my 2014 ford focus put still won't have one push start have to hold button in to start any ideas l
Both clutch switches? One is for the starter. The other is for cruise control.
Does it tell you to press the brake?
No starts with clutch down now got cruise control back just have to hold start button to start
Ok, I'm not sure this is really a fault. Could just be caused by low battery charge. I know they should start from just a quick jab but I always held the button a bit longer as if it was a key in start position.
If it's not just battery charge then you're probably looking at a BCM fault. The button itself isn't smart, that just makes and breaks the circuit. The choice between just ignition or ignition and start is made inside the BCM.
