Fiesta Mk 6
havnt got a workshop manual yet but could not work out how to remove rear brake drum to check brake wear,any advice?
under the metal hub cap in the centre there is a 30mm nut, remove this and pull the drum off. nut should be torqued up to 235Nm
thanks for the reply,i noticed the hub cap but didnt want to prise it off because i didnt realise that there was a nut under there
