First Service
My car was registered on the 3rd of March 2010, so I need to have it serviced before that date. Do you know if it's possible for me to get it serviced right now and not void the warranty or is too soon? Also, how much did you pay for your first service?
This is my first new car so I have no experience dealing with servicing so any advice is much appreciated!
Cheers!
Hi
The price of a ford service ranges from £175-£215 so it pays to ring round your local dealers to see who offers the best price.
The First Service consists of the following
Instrument gauges, warning/control lights and
horn
Check operation
Clutch Check operation/adjust, if necessary
Washers, wipers Check operation/adjust, if necessary
Inside Vehicle
Exterior and respective control lights;
instrument cluster illumination
Check operation/condition
Handbrake Check operation/adjust, if necessary
Seat belts, buckles and stalks Check operation/condition
Odour filter Renew
Warning vest Check availability - if applicable
First aid kit Check availability and expiry date - if applicable
Warning triangle Check availability - if applicable
Outside Vehicle
Road (MOT) test Check regarding next road (MOT) test due date - if applicable
Emission test Check regarding next emission test due - if applicable
Under Hood
Wiring, pipes, hoses, oil and fuel feed lines Check for routing, damage, chafing and leaks
Engine, vacuum pump, heater and radiator Check for damage and leaks
Coolant Check anti-freeze concentration: °C
Coolant expansion tank, washer reservoirs and
battery
Check/top up fluid levels as necessary - in case of abnormal fluid loss, a separate order is
required to investigate and rectify
Battery Visual check for leaks - in case of abnormal fluid loss, a seperate order is required to
investigate and rectify (LTS 31 214 4)
Headlamp alignment Check - adjust alignment, if necessary
Brake fluid Check/top up fluid levels as necessary - in case of abnormal fluid loss, a separate order is
Under Vehicle
Engine undershield Remove/install engine undershield, if fitted (LTS 21 130 4)
Engine Drain oil and renew oil filter
Steering, suspension linkages, ball joints,
sideshaft joints, gaiters
Check for damage, wear, security and rubber deterioration
Engine, transmission Check for damage and leaks
Pipes, hoses, wiring, oil and fuel feed lines,
exhaust
Underbody Check condition of PVC coating
Tyres Check wear and condition, especially at tyre wall, note tread depth
RF mm, LF mm, LR mm, RR mm
Brake system With wheels on, check brake pads and discs for wear. Check rear brake drums - in case of
abnormal fluid loss, a separate order is required to investigate and rectify. (More often
under severe duty conditions).
Outside Vehicle
Engine Refill engine oil. Reset the oil change indicator, if fitted.
Tyres Adjust pressure
Instant mobility system Check best before date on tyre sealant - if applicable
Spare wheel Adjust pressure, check wear - condition (note tread depth)
mm
Interval 1 Years (12500 ml)
Repair/Order No
Reg. No.
Reg. Date
Radio Code
Mileage ml
Outstanding Field Service Actions. Please ensure they are completed.
Outside Vehicle
Luggage compartment lamp Check operation - if applicable
Service reminder sticker Affix to driver side B pillar
Extended Period Maintenance
Brake system Every 2 years - Renew - brake fluid (LTS 12 154 4)
Air conditioning Every 3 years - Check temperature at the evaporator outlet tube. Check air conditioning
lines for damage and leaks
(LTS 34 619 1) (TSB 67/2002)
Cooling system Every 10 years - Drain, flush and refill with Super Plus
(LTS 24 122 4)
Camshaft drive belt Every 100 000 miles/8 years - Renew (LTS 21 304 9)
Auxiliary drive belts Every 100 000 miles/8 years - Renew (LTS 21 567 5)
Extra Services and Additional Offers * (optional - upon customer request / charged seperately)
AC maintenance package Air Conditioning (A.C.) system check. Apply A.C. cleaner to air distribution system.
(LTS 54 552 4)
Odour filter plus Upgrade odour filter to odour filter plus
Test Drive
Test drive Perform test drive after routine service
as you will see its 1 year or 12500 miles whichever occurs soonest.
How many miles has your car done
Jamie
Not sure why you would get the car serviced early (unless you're past 12500 miles of course) as you're effectively wasting a month, but there's nothing to stop you doing so.
My first service was only £100 odd.
My first service was £99. If you live in an area with a few dealers then play them off against each other until you get a similar deal. Also, don't bother servicing your car until 1 year or 12k miles, the car doesn't need it and you're just reducing the time until your next service.
Thanks guys, the only reason why I wanted to get it serviced now is because I'm moving from Bristol to London at the end of the month, so I'm hoping it will be cheaper in Bristol and I already know a good garage. I wanted to know if it was possible to do it early without voiding the warranty.
I will probably try and get it done the week before I move, from the check list it sounds like it's going to take all day to service.
2-3 hours mine took but they gave me a courtesy car so i left it with them all day :)
Jamie
