Fuse Replacement?
Hi.
I have a ford focus '01.
I use the cig power inlet for my dab radio.
However it now has no power. Do you think it could be the fuse? Where are they on this car?
Thanks.
Hi.
Thanks.
chances are it is the fuse, try behind the glove box on tthe passangers side, open it, squeeze the sides, uncouplethe retainers and the glove box opens fully to allow acess to the fuses.
Cheers. Will give it a go. I assume the fuses are readily available, Halfords, etc?
yes you will be able to get them at halfords
find a local motor factors...pence per fuse rather than halfrauds pound per fuse!!! :rolleyes:
Thanks for help.
Iv located fuse box, but have no manual. Have found a manual online for the US drive car, although the fuse box is in a different location, it seems similar.
On the diagram is showing the Cig fuse as Fuse No.46. 15amp.
Can anyone confirm this?
Cheers
Thanks for help.
Cheers
petrol focus 2.o year 2000 central fusebox cigarette lighter f46 @15 amp.
Lovely. Cheers
Thanks. All sorted
