Footwell Lights Powered By Gem? Help!
Hi all, I was just adding some rearfootwell LED's to my car when the footwells completely cut out. Something has blown and I am pretty worried!
What powers the footwells and can it be fixed?
Thanks,
Harvey19
nothing is wrong ya just done the wiring wrong most likely it happened to me.... if ya take them cable off and go through it all again it will more than likely work, i figured it out that by somehow putting the wrong parts of the cables together then it can short it out... if ya already took them off and still nothing i really dont know.. have a look at the fuse box behind the glove box one may have blown
I wired mine to the front ones, I'm no electrian, it scares me, had an auto spark wire the driving lights oin both cars, but rear footwell leds no problem!
I'm running everything off the cable that powers the glove box ambient light strip, when the lights cut out I removed all the cables and started from scratch but it seeks like this cable now has no current. I don't know what to do! I fear it will be expensive as I have obviously voided my warranty by cutting into wires.
What lights are you using for the rear footwell ?
you cut into the wires??? i used halfords cable lock connecters... cheap and nasty but do the job!
