Sensor
When driving, sometimes as i go over a bump the speedo needle will drop and mileometer cancels out and if the radio is on the volume will reduce, then another bump can bring it all back.
The car is a ford fusion 2002
Had a sensor replaced a couple of years ago because the engine warning light kept coming on and off, as it sometimes does this now.
Is this something i could fix myself?
check the connections at the vehical speed sensor are ok.
Could you tell me where to locate this
