De-Badging, Help!
Thinking of de-badging my zetec s, just wanted to know the best way of doing so. Would really hate to damage it!
Please get back to me soon, thinking of getting it done in the next few days.
Thanks Liam..
I de-badged my previous car (a Clio) and am looking to do the same to my Fiesta soon too.
How to go about it depends if the badge is held on by pins or glue. If it's held on with pins then the resulting holes from removing it would need filled, however since it seems quite a few people seem to have de-badged their cars I'm assuming it is just glued on.
For my previous car I de-badged it as follows:
1) Heat the badge with a hair dryer to soften the glue (but not too much that it will damage the paint).
2) Use dental floss and run it behind the badge to slowly peel it away.
3) This will most probably leave a glue residue on the paint, so peel as much off by hand as possible.
4) Wipe over the area using a damp cloth and then a tar remover. This should remove the majority of the remaining glue.
5) In my case the last time I did this there was still slight marks left on the paintwork so I used T-Cut on the area and this got rid of any remaining marks.
I'm a bit of a perfectionist and so after this I also polished the boot to leave a totally flawless finish.
As I say this was for a Clio so maybe wait until someone who's done this on a Fiesta before going ahead, but I hope this is helpful :)
get a knife (kitchen spreader type) and slide it behind, this will remove the badge, but leave most of the glue, just peal it off!
I did mine exactly how Graham89 did his and the badges have no pins just glue so everything will be fine. ;)
i just took off my FOCUS, ZETEC and TDCI badge off... i used a flat head screwdriver with masking tape around the end to stop stratches, my fingers to pick the remaining glue, t-cut metalic to remove the residue etc and a good old car wash...worked a treat.
didnt need to use a heat gun they just pull off. i beleive the only ones with screws are the actual ford badges.
Hair drier (30sec,s),or leave in a sunny position for a while, then pull dental floss or fishing line behind badges.
the heating isnt needed just makes the job alot easier.....
follow the first reply and you cant go wrong (y)
non of the badges are pinned, even the ford ones, but they being a larger surface area are harder to get off!
preferably fishing line, less chance of that snapping halfway through
Thanks a lot! Going to give it a go in the next few days. May post some pics if I can work out how (can tell I'm new to forums).
Its really easy on the mk7's the glue thats held on doesnt really stick to the paint work unless you fishing wire the badge off and leave the glue in place. I found it easier to heat it up with hairdryer for 30sec-1min and use my bank car to pull all of it away, bank card isnt going to scratch paint work. I was left with very little residue, just dirt, Get a wet cloth, maybe a dab of shampoo, give it a quick clean, then i got some AG Tar/Bug Remover on it and it came up as new like they were never there. I was afraid there would be telltale marks but there wasnt.
Heres from another forum Im on.
How it looked.
Take one 2010 Fiesta
One Extenstion Cord
One Hairdryer
One Halifax Bank Card
Two Cloths(one for water and shampoo,one for tar remover)
Add 15mins of your time
and the result is:
Hoep this helps
