Oil Pressure Warning Light And Chime
On my 60 registration Titanium diesel ( 95 HP 4000 miles only) on cold start I am getting an oil pressure warning light and chime coming on for one second. It has been checked on the Ford computer and they say all is OK. Has anyone else had this problem? I suspect a faulty oil pressure warning sensor as there is plenty of oil in the engine and it only happens on cold starts. Obviously I will be going back to the Ford garage but just wondered if the problem is known about?
Have you tried turning the key to stage 2, leaving it till all the bulbs turn off, turn finally starting the engine??
Yes tried that thanks. Oil light and others do not go out until the engine is running. Will ring Ford today for re investigation.
