Timing Belt Again.
Timing belt change due, there's quite a price difference between OEM and say Dayco and others. Are Dayco okay?
Dayco are one of the biggest in the game and make alot of OEM belts
Thanks...looking to do the work myself and it says in the Haynes that I need a special puller for cam sprocket, is this strictly necessary or can I manage to refit the belt without having to loosen that?
Thanks in advance.
You will need to remove the bottom pulley to be able to remove the belt. I used to do it with a drift (large screwdriver or block of wood) and a hammer. Takes longer than with a pulley puller and can get frustrating as it isnt removed square to the crank shaft as the pullers pull the pulley evenly.
