Buying Mondeo
Hi, im going to look at a 2005 FORD MONDEO 2.0TDCi 130 Ghia 5dr [6] Diesel Hatchback at the weekend. Its got 100K on the clock with a FSH. Is there anything i should look out for?
genral wear on front tyres,
cambelt tensioner thinging,
last time egr was cleaned,
saggy rear bumper,
injectors - the delphi injectors are not the most reliable and often loose there code or pack up all togeather so look for black smoke
aux belt - this can start to vibrate,you have to replace the belt and pulleys to cure
egr valve - these can become choked and give out fault codes, its a simple job to clean but a messy one
intercooler hose - these can split creating black smoke and a flat spot at around 1800rpm, its the big hose from the bottom of the egr valve
alloy wheels - these can flake because of the brake dust eating into them
any kind of rattle or noise from the clutch area could be a failing DMF at around £800 to replace not cheap
starter problems is also another sign of a failing dmf as the swarf blocks up the starter
and because of the weight of the engine front tyres will not last much more than 14000 miles.
Thanks alot looking tomorrow hopefully all ok.
