Mk 6 Overheating/leak
Hi, was driving about tonight at work when the car leaked all its coolant and there was a lot of steam coming from the back of the engine, any ideas where the leak could be coming from? it was losing all its coolant within about a mile and a half. Any ideas whats causing it? all that car has done in the 2 and a half years ive done it is leak coolant from different places and over heat.
Steve
Steve
Water pump gasket.Thermostat housing.
Water pump will need replacing,this will entail replacing water pump and gasket.if this the case also will need cam belt changing,because water leaks onto cambelt.
Also thermostat gasket leaks,this will need new thetmostat gasket and thermostat housing(plastic)
These items seem to be a common fault.
Sorry to be the bearer of bad news,but hope this helps.
