Ford Streetka Fault & Codes
Hi all,
Have a 2003 1.6 Ford Streetka, about a week ago the car wouldnt start when cold. Then Later started ok, but is now stuttering through 2nd and 3rd when it reaches 2000rpm.
Put the Dash into test Mode and was a little overwhelmed by the Results, it threw out as follows (forgive me if some 1's are actually I's etc)
1- 106
1
dt 412
0
5c 0
t 74
tc 13
f 111/113 (was flashing between them)
fc 3d1
p 0
t9 64
ct -6
19 -b (or 6)
FLI -0
PO 70
My initally thoughts before seeing all those were, Lambda sensor, spark plugs, Leads, coil pack and hopefully not CAT.
Would appreciate any help/ advice.
Chris
I dont know what your codes mean, but most common problem is the Coil Pack, followed by the Leads and then the plugs.
