Induction Kit In My 1.3
I got a service 2 days ago and my mechanic said that my induction kit is probably slowing the car down because its not gettin the correct mixture, is there a may to make the mix right?
Yea.
Get rid of the induction kit, re-fit the standard air box. Buy an uprated panel filter such as a K&N, the drill the bottom of the air box and fit a 2nd air intake.
Ford have spent hundreds of thousands of pounds developing the standard airbox and have done a fantastic job with it, and mny times it has been prooven that the standard air intake set-up will give more gains over an induction kit.
In the majority of instances the induction kit you have fitted will be sucking in hot air from the engine (Heat soak), therefore reducing the power it creates. Fit the standard stuff back and it will now only suck in cold air, which means, cold air = more power, hor air = Less power.
