Radio Code
Hi I need help unlocking my radio due to battery being disconnected, I have pressed 1&6 at the same time (I read this will bring the serial number up) and the info that came up was: FDC2005M144399, C307 02-03 17D_C, C820218 SA811000, NOV 7 2004, JA CB AT RW RL AR, don't know which bit I need or if this is any use to me at all?!
Any help would be greatly appreciated
hi jennie, you need to pull your cd out the dash and you will see a model number, if you post it on here i will give you your code, ;)
your m number was in that load of digits,lolol
8351 ;)
8351 ;)
Thank you all sorted now x
