Where Is The Power Steering Bottle?
i have the mk8 fiesta, and have noticed oil under my car, all other oil levels are fine, but when i came to check the power steering level, there is not one under the bonnet, and no sign of it in the manual either. does anyone know where i can find it so i can check if its leaking?
Hi Ben, not sure where the fluid bottle is mate but if you dip a finger in the oil on your drive that'll tell you if it's p/steering oil cos it'll be red (assuming your car's not automatic), on another note, if you can tell which is your p/steering pump (usually at the front of the engine at the belt end) then follow the pipes one off them will lead back to the p/steering fluid bottle.
Hope this helps.
From a conversation I remember having previously, apparently its under the headlamp assembly. I will try and dig out the thread!...
EDIT
... aha - here we are -
Seems to be same year - potentially same car as yours - so hope it helps!
