What's Wrong With My Fusion Brakes?
I was driving by a interstate way, and suddenly I had to brake but car pass over a little hole in the road. After that, ABS does not work, brakes have been working but I have to push the break pedal and pumping it for braking the car. ABS ligth indicator is off, car brakes are as non ABS car brakes systems.(regular and older systems)
What can I do to reset abs? Thanks all in advance
on the wheel that hit the pot hole i would check the sensor and abs ring for damage,i guess every thing will be ok because if there was any damage the abs light should be lit,but its worth a check.
