Non Start
2007 ford ranger 2.5 diesel non start
It will start when i use easy start sprayed into inlet housing, all lights on dash ok
once truck is running it seems to be ok, no issues.
when turn off key to restart, no joy!!!! will not start- this happens when hot or cold.
I have checked glow plugs, battery, fuses in cjb, bjb also relays ok.
I feel its a fuel issues? any help out there
  • 1 month later...
HI, iv not really had any non starts when hot but i have done loads of fuel filters for lack of power and changed glow plugs on these for hard to start. Would defo put a fuel filter on it and give it a go.
Hi cheers for the reply. I have basically ruled out the fuel filter housing by a remote feed to the fuel pump!!! still wouldn't start.
I have also found out low fuel pressure using a snap-on code reader. the readings were about 10-15 bar at cranking pressure. Also done a leak back on all four injectors which turned out to be good. I have replaced 1 glow plug also an earth lead which bolts onto the cylinder head, look out for those. in the process of fitting an other fuel pump. cheers
