Ford Focus 18
P1631 Main relay malfunction i have a ford focus 1.8 02 plate and have this fault where would i find to fix it thanks
start by disconnecting the battery, then go to the fusebox, remove and replace (securely) all the wiring harnesses.
is that engine harness only or is it dash board harness aswell thx
Hi Peter,
Just start with the fusebox in the passenger footwell, that isnt the engine harness but at least allows you to rule out the issue as being anything more than a loose connection.
ok thx
