Front Suspension
Hello, does anybody no roughly how much it will cost to get lower mount bushes on the front suspension? Thanks
Do you mean lower arm bushes?
Unfortunately ford don't sell replacement bushes for the control(lower) arm.
Aftermarket you might be able to get the small middle bush in the arm but will struggle if its the main bush that you need.
In my opinion I'd replace the entire control arm.
My sincere apologies. Just done some research and spoke to my supplier at eurocarparts and the both bushes on the arm are available.
Hit me up if you need anymore info or part numbers.
buy a new arm/pair.. i had to 2 weeks ago... as the rear bush on that was bust...... took them off and found my ball joints has loads n loads of play, was a good job.....
the cost will be very very similar, so better buy new, but not from ford, they want 190 per arm
