Sony Dab Radio
I've seen on eBay a Sony DAB Radio which is alone identical to the AM/FM one in my 09 Focus. It even has the same Bluetooth phone connections. Apart from needing a DAB aerial will this unit fit ok?
You will have no problems fitting the DAB radio into the car.
I have a guide link under this message that I made toassist another member recently concerning the installation and parts needed from Ford (wiring and aerial parts required).
Hopefully you will find it of some use?
The link is also here in case you need it, the file is in PDF format so will open with Adobe on a PC and is fully printable for easy reference-
http://www.fordownersclub.com/forums/tutorials/article/210-guide-to-installing-a-ford-dab-radio-to-your-mk2-mk25-ford-focus/
