Startup Video
Took this the other day,it's been doing it for a while and I guessed glow plugs,after the recent engine system fault I've had and with it being intermittent I forgot about it and started thinking it could be egr or maf sensor.
Took it to a garage today to get it read, the fault codes p0670 for glow plug module control circuit and u0422 for invalid data received from instrument cluster panel or body control unit came up.
Would you say that's glow plugs or possibly just a relay fuse? Or is that video completely normal of a diesel and unrelated
Never let the diesel run to the reserve or kiss goodbye to your fuel pumps
does this issue only happen on a cold start? if so then it will most likely be the plugs or circuits/ground as the error shows
What do you mean run to reserve?like low on diesel? And as far as I can tell it does it on the morning start when it's cold,then it's fine after that.only had it since June/July and it didn't do it then.
