Mk2 Dash Conversion To Cubby Storage?
Just came accross this pic and although left hand drive is this possible to convert my mk2 dash to the funny hole storage
post-49486-0-84259300-1390599681_thumb.j
Yes it is completely possible to retrofit the Titanium/Ghia storage compartment. The picture you posted is taken of my car after I retrofitted the storage compartment. The holes needed to fit the storage compartment are marked at the bottom of the dashboard. After the dashboard is removed from the car you can simply cut the holes and click the storage compartment into place.
The biggest problem I suppose is to find a storage compartment. A complete used storage compartment which is in good shape is pretty rare. New storage compartments are really expensive and because the rarity a used one will also cost quite a lot of money.
the clips break constantly that hold the cubby door down personally i wouldnt waste my time cutting holes in the dash for one of those thats why good ones are hard to find they are all broken
I have one in my titanium and it all works ok no broken clips,i never ever use it so wouldn't go cutting a dashboard apart to fit one.
Oh right, I didn't realise it was a cut out dash job. I don't think I'm that bothered, if it was an easy thing then yeah but maybe not now then lol. I will stick to buying some bits for hydro graphics then
The dash storage is not very usefull TBH , as you have to be carefull what you put in there , summer months means it gets very hot , and also if you put something loose in there it rattles around , but it does have its use's , i used to keep my screen shammy in there.
Ok thanks for the responses guys
