Reverse Lights Mk2 Mondeo Late Version 2000
hello 1st thanks for the info on the starter motor IT was the duff batt I got with the car sorted now cheers!,
Now new problem is that no reverse lights, new bulbs and the fuse checked all fine could it be the gearbox switch? everything else is working but these as we know its MOT fail . thanks .
Gearbox switch is a good call. You should check that there is actually power getting to the holder. If there is, it could be just poorly making contact and causing no light, otherwise though, the reverse switch is almost a definite advised to replace!
thanks it was the switch at the gearbox £10.00 fix job done thanks again.
