Ford Focus Mk1 Tie Bar / Rod Rubber Bush Rear
Hello,
Just had an MOT failure on my 2003 Ford Focus MK1 TDCi Ghia.
One of the issues is deteriorated rubber bushes on the rear tie bar/rod.
Problem is I can't seem to find the correct bush/rubber to buy to do the job.
Can someone give me a part number or point me in the right direction?
All I seem to easily find on ebay is anti-roll bushes which aren't the correct item.
Any help appreciated.
Tie bar/rod? Which bushes do you mean?
I mean this.....
What is the proper name?
Those are rear anti roll bar links, also known as drop links.
www.fordpartsuk.com £26.36p Ford Focus MK 1 rear anti roll bar link kit.
Thanks for confirming that. Assuming that is the part they're on about on the failure!
If the word tie-bar was mentioned, the bush is mounted in the wheel arch. This is a different bush to in your photo.
Ok, thanks. I'll have another look since I've probably got the wrong part!
The tie-bar bush is located on the extended arm of the pressed steel hub carrier and is mounted up in the wheel arch.
