Focus Radio Interference
Hi, I have a focus 2005 plate 1.6 zetec and it seems to have radio interference on the fm channels. I have tried replacing the aerial and cable. I have fitted a booster to the aerial and ive fitted a suppressor all of which has made no difference. I have also cut the earth wire and wired it to another earth but still no joy.
I was wondering if anyone has any ideas what causes this? I had a 55 plate focus before and that was fine. I just cant understand it.
have you fitted any other LED lights, 12v socket devices, cree lights etc?
These can often be a cause of interference.
Not as far as i know. I was thinking of replacing the ht leads and see if they were causing it.
Hmm, mine is kind of the same, but not really...
I can access quite literally ONLY 2 radio stations, in the busy airwaves in Surrey. (At home I can receive over 12 channels with a tiny antenna.)
I have replaced the antenna (after the last owner snapped it off), but that did nothing to improve the signal. I am thinking the aerial cable might be disconnected from the back of the headunit (stock one), any other possible reasons?
Check the cable joint behind the driver side A panel.
