Drift Shaft Help?
I have installed a new off side drive shaft on my Ford Focus 1.8 TDCI 06 plate and now there is a clunk when I shift in low gears or pull off sharply and when it his pot holes at low speed. Any ideas what I have done wrong or something else bust?
Did you have the bottom balljoint out? Make sure its back in properly with the correct pinch bolt fitted or it will be flopping around.
Sounds like its balljoint or bush related.
Hi thanks I did have ball joint disconnected but also put new bushes in on both sides I'll check the ball joint but what should I check with the bushes could I have done them wrong some how?
I would double check everything is tight and the drive shaft is home properly within the hub could be floating .
Got under it and tightened everything with extra leverage and now it's sorted so thank you.
Glad you got it sorted when ever I do anything in that area I always double check everything better safe than sorry
