2009 Mondeo 1.8 Diesel K-K-K-Kangarooing
Hello
My brother in law's Mondeo is sick
You can drive it IF you tickle the throttle and i mean tickle.
If you press the pedal 10mm it'll start kangarooing and will slow down
From cold you wouldn't notice it if you had a gentle warm up cycle.
Disconnecting the MAF sensor kinda helps. In that it doesn't want to boost anymore but will still kangaroo but not as easily
Fault codes have been cleared and car driven for ten mins
Fault codes are
P1100- AIR FLOW
P2000- NOX TRAP
P0028- INTAKE CONTROL
P100C
P2012
P0600- SERIAL COMS
P0064- HO2S HEATER CONTROL HIGH VOLTAGE
P0100-AIR FLOW
P2800
P0CLC
P3000
CO64F
C1220- ABS LAMP
C2E20
Amy ideas
Matt
Disconnect the battery and then go to the internal fuseboard, disconnect all wiring harnesses and refit in turn. Also check all the earthing points and clear them as necessary.
