Tow Bar Electrics
i recently fitted a tow bar to my ford fiesta. it was quite easy but when i came to put the electrics in i got told i should use scotch connectors. when i went into our local car bar the guy said to be careful using scotch connectors on modern cars as some computer systems in cars don't like them and see it as a fault in the wiring. this could cause the car to still be trying to figure out whats wrong while the car is turned off. =flat battery. can anyone help in this topic. i just need to know whether i should use scotch connectors or use a different way?
Jonny
I wouldn't use those scotch connectors, they are just a bodge!
Stripping the insulation back and soldering the wiring is the best way to go. You just need to insulate the soldered area afterwords.
A proper soldered joint will be many times better and will not fail through time.
+1
Solder is best, then crimp type but connectors plus insulation as second choice. Personally I wouldn't use scotch lock connectors.
