2007 1.8Tdci Leak Off Pipe Problem
Hi all, i did a quick search but not found 100% what looking for.
Anyway my car leak off pipe is leaking diesel from one off the leak off pipe seals. It looks like the rubber inside has got a slit (furthest one to the right hand side of the engine) and is leaking diesel. I was wondering if i could just replace the rubber if so where can i get the rubber and how do i fit it or will i need a new kit. The annoying thing is the kit already on it is only12 months old.
Thanks,
Neil
i think last time i checked the seals can be bought seperately, youll probably have to ring the dealer as theyll have the part. if not then youll have to get the whole set again im afraid.
are you 100% sure it is the leak off pipe and not the injector seal/pipes?
Had the injector seals replaced 3 months ago. When you wiggle the leak off pipe where its got diesel on engine it starts leaking out a tiny bit.
