Help Need Please
I have a 2011 fiesta 1.25
I have a got a weird noise coming from my n/s wheel somewhere. It's like there's something moving when I brake and then when I pull off again.
The car was in a crash a few weeks ago on the n/s front wheel. Resulting in it having a
New bottom arm
New anti roll bar
New anti roll bar drop links
New hub
New shocker
New steering rack
New subframe
New drive shaft
I have checked everything more than twice now checked all bolts and there all tight even has a bar in there to see if the is any play in wot and nothing seems to move.
What would ant one else suggest I should do its driving me mad
Sent from my C5303 using Ford OC mobile app
It's don't do it over bumps thought only when I brake. Pull off. And when turning
Brake disc?
I don't no I haven't checked that but I will tomoz as its driving me mad
So had the brakes apart cleaned it all up and put back together and it's still making the same noise as before had any body else got any suggestions
If there is no damage to the disc it could also be the brake bias ie the amount of fluid being sent to the pads under braking, get a garage to check it out, shouldn't cost a lot
