Cylinderhead Bolts
could someone please tell me if i need to chang cylinderhead bolts when doing gasket also when i put my fullbeam on my ofside light goes of lights working fine otherwise need fixed for mot
its ok ppeople just priced them copers will replace them cheers
still need helpp whith my front ofside light when i tern side lights on work ok main beam ok. when i turn my full beam on main fullbeam comes on on the near side light but turns full beam of on drivers side light just leaving side light when i turn full beam back off main beam comes back on
dan changed buib twice fuses ok the lights work fine till i go to flash somewonout then drivers side goes out let the stock go it comes back on
cheers dan coulyou send me somthing with timing marks am hopless on computer i think my head gasket is on its way out
dan i had an extra fuse in my fuse box it was only conected to one of the wee metal bits on fusebox must have been causing bad earth sorted now cherrs
it had cambelt changed 10000miles ago i will figure it out at weakend when i strip the cover of cherrs for help
cheers dan
